How to use sheet metal model with loft
kevin_mason558kevin_mason558 Member Posts: 60 EDU
I'm trying to make a chute - an offset reducing cone
I have drawn it in loft but trying to get the pattern to cut on the plasma cutter
how do I convert it into a sheet metal pattern please thanks
https://cad.onshape.com/documents/7acc48861988f7e65e14b7c6/w/1283ab2e6f95f7b5c583f4f9/e/f97633e335d4ffd017350dd7
