Symmetry tool
M_BÖHMEM_BÖHME Member Posts: 10
Hi
When I import parts, i often need to check symmetry. How do i do that ?
It seems that the simple tool is missing ??
  • eric_pestyeric_pesty Member Posts: 2,272 PRO
    There isn't an automatic way but you could do a split feature (using a mate connector directly) and mirror the one half with the "intersect" option, any material left indicates assymmetry so it doesn't take a lot of steps.
    I should also be pretty simple to do this in Featurescript if that's something you do a lot...
  • Caden_ArmstrongCaden_Armstrong Member Posts: 294 PRO
    I'm reviving an old thread, but I have made a feature to achieve this:
    https://cad.onshape.com/documents/dbc618f5385d62322ab64ddf/w/8e8cc30dbe8d631926fe4be4/e/303589cc9047018cea1735d1
    www.smartbenchsoftware.com --- fs.place --- Renaissance
