evaluateSpline: Parameter at index 0 is outside the knot vector
Jonathan_Hutchinson
Member Posts: 148 PRO
I used a Split feature on a curve (helix) entity, and wanted to then subdivide this split version of the entity into line segments. However, I got the below error. Is this because the curve needs to in an ideal world be reparameterised between 0 and 1? Has the split operation done some funky business where it's almost treating it like a trimmed surface, and now no longer exists in the domain of the curve? I couldn't initially see anything in the FS documentation to fix this.
@evaluateSpline: Parameter at index 0 is outside the knot vector.
The hack I did was then using a path instead (FS: evPathTangentLines to evaluate point at parameters) which was a bit more clunky I suppose, but seemed to be the workaround to reset to 0-1 again. Is there an option somewhere else to reparameterise or, as you mention, rescale the parameter before subsequent operations without Paths?
export function normalizeKnotArray(knots is array)returns array { var ret = knots; var minKnot = ret[0]; var ct =size(knots); if(minKnot !=0) { //resets knots to start at 0 for(var j=0;j<ct;j+=1) { ret[j] = ret[j] - minKnot; } } var newMax = ret[ct-1]; if(newMax!=1) { //normalizing the max knot to be 1 and all others scaled in between. var mult = (1/newMax); for(var j=0;j<ct;j+=1) { ret[j] = ret[j] * mult; } } return ret; }
