Sweep along parametric curve not rotating about axis
Hi all,
I'm trying to sweep a profile along a parametric curve. When I sweep it along a helix, I get what I want, but when I sweep it along a parametric curve, it doesn't rotate the profile about the x axis/origin.
Left view: Helix on outside, parametric curve on inside.
Front view: Helix straight line, parametric curve sine shaped.
Resultant sweep: the parametric curve-based sweep is acting as if I selected "keep profile orientation" but I did not.
Any ideas on how to force the sweep to rotate about the origin and not keep the profile orientation?
Thank you!
Thank you!
Hi @Greg_Daly, try using a custom feature.
Sweep normal by @mahir should do the trick.
There is a little + icon at the top of the documents page, click that to add the feature to your toolbar.
step 1: extrude a cylinder with the same radius as my figure:
Step 2: use the surface of the cylinder as the reference for sweepnormal:
