Stuck on pattern generation...
I'm trying to generate a circular pattern with the feature on the surface of the short arm... any ideas?
https://cad.onshape.com/documents/866ac0b0a2b67da7315c5ced/w/78e8100590e91ac302817fe4/e/3546f2cfffb76963ef75e6f2
  • S1monS1mon Member Posts: 3,745 PRO
    Looks like you solved your problem.
  • david_vernierdavid_vernier Member Posts: 4
    Yes... Slicing the feature off the surface allowed me to do the circular pattern, then just Boolean it all back together... Thanks
