assembly support
I'm going to have student designing a bird house in class with onshape.com. Let's say its 8" x 6" side walls and a basic front and back, bottom and roof pieces. The designs of each side as a part is all set. I want to create an assembly and put everything together. Then the kids can produce a drawing and use that to make a scaled down bird house, and then create a wood birdhouse based on this drawing. I'm having trouble with the mating sides and getting this together. Could someone please give me a few pointers? Thanks very much
Matt_Shields Member, Onshape Employees Posts: 740 EDU
One of the things that makes Onshape different and awesome is that you can model parts that share geometry in the same Part Studio. Check out this document:
https://cad.onshape.com/documents/1b397a5000407e20c9db9cbf/w/01c2dda7e955a87f24ebb1e0/e/f41a3b448762d7cc8c15346b
https://learn.onshape.com/learn/course/introduction-to-assembly-design
Assemblies in Onshape are really easy. For a birdhouse, you'll probably just be adding Fastened mates to corners of pieces.
If the students are going to do actual design, then the #1 tip would be to design the whole house in one Part Studio.
I personally think Matt Shields already answered enough above, but if you need help, give me a private message. I have time over this weekedn.
