Boolean fails for non-manifold
tim_elstontim_elston Member Posts: 4
https://cad.onshape.com/documents/abee862d6bd51cefcff28e3a/w/104459627f81061d3c1e6ad1/e/820a39916cd296516a97f53d
Sketch 7 and 8 are lofted and thickened to form a body - part 7.
Fill 4, thicken 7 and Boolean 6 seal one end of the body - still part 7.
Fill 5 and thicken 8 seal the other end - part 8.
Boolean parts 7 and 8 fails for non-manifold!  Why?  How to resolve?
  • S1monS1mon Member Posts: 3,644 PRO
    The end cap (part 8) that you created has faces on the edges which are not quite coincident with the inside of the lofted tube (part 7). When surfaces wobble in and out of being coincident like that, it's likely that you'll get some point or line contacts, which the Parasolid kernel can't deal with.
    It would be much easier to loft a solid and then use shell to get the wall thickness that you want. That would turn 7 features into 2, and be much more robust.
  • CFraser100CFraser100 Member Posts: 5 EDU
    Have you checked they share a common area or are touching?
  • tim_elstontim_elston Member Posts: 4
    Thank you! Another new approach to design approaches.
