unable to complete loft
I have been trying to loft these two surfaces to each other, but there seems to be an error I can't figure out. Thank you!
  • Jacob_CorderJacob_Corder Member Posts: 139 PRO
    try to split your path in half and run the loft in 2 attempts.  The loft hates creating full "revolved" type surfaces.
  • S1monS1mon Member Posts: 3,651 PRO
    Can you share a public document? It’s difficult to fully tell what is going on from just the screenshot.
    You may not need to do Extrude 1 and 2, or they might want to be revolves with a very small angle. If the Sketch 3 path is a full circle that may be causing issues with it trying to create a closed loft.
