CNC router sheet with layout of parts - assembly export DXF
Gerard_Boterman
Member Posts: 31 ✭✭
I have created an assembly with multiple parts within the size of a timber sheet 1220 x 2400 mm, to be CNC cut.
Trying to export in DXF I seem to have to create a drawing first. (Why can't I select all parts and export?)
I created a drawing with a blank sheet A3 at 1:1, all parts exceed the sheet in this case.
I right-click the drawing tab, then export the DXF. This should be 1:1.
When I open the drawing im eDrawings (SW) and measure the size, it is 25.4 of what it should be.
What am I doing wrong? Or is this a bug?
Not sure if eDrawings is misinterpreting the units. Maybe change your workspace units in Onshape and re-export.
Also, have you seen the Auto Layout custom feature? I love it!
