Image Rendering blueprint view?
SophiaCoffeeSophiaCoffee Member Posts: 4 PRO
How can I get my assembly to look like the blueprint mode seen below?
  • MichaelPascoeMichaelPascoe Member Posts: 2,767 PRO
    edited August 2023 Answer ✓
    @JNPOWELL, the attached image is from Onshape's Render Studio beta, is this the image you want your assembly to look like or is there another image?
    Render Studio creates block out ghost renders of the part while the final part is being rendered. This is so that you can move the part around while waiting for it to load, like this:
  • SophiaCoffeeSophiaCoffee Member Posts: 4 PRO
    Yes, I like the way that appearance looks, I was wondering if there was a way to transform my entire assembly to look like this?
    There are a few different render modes within an assembly without having to go to render studio. The closest might be "Translucent" however it wont let you hide edges while translucent. The "Hidden edges removed" looks and kind of like a drawing.
