2-directional loft with shell
daniel_centore704
Member, csevp Posts: 4 PRO
Hello!
I'm trying to do a loft operation where:
* Part of the loft is best represented by a loft from the front to back, so it captures the outline of the back plate perfectly:
* Part of the loft is best represented by a loft from top to bottom, because the back plate does not extend all the way to the top of the model and thus cannot be used as a profile beyond that point. I made this loft match the tangent of the first so the curve is fairly smooth between them:
I then did some extrudes and a boolean operation to merge the 2 lofts:
This feels super hacky and I'm interested in a cleaner solution - it seems like ideally this should just be a single loft operation somehow? I couldn't seem to figure out a way to do that unfortunately.
While this solution is hacky, it wouldn't have been the end of the world for me, except that the approach seems to be breaking the shell operation.
So my questions:
* How can I accomplish this loft in a cleaner manner?
* How do I fix the issue with the shell operation?
My workspace: https://cad.onshape.com/documents/fdbd1b02753809d6d963f4d6/w/2480c22a66c22d0958468a3b/e/8b4a8971c7745b7c5ae53f5f
So my questions:
something like this?
I eliminated some of the profiles in the loft to get smoother transitions. With some thinking and a bit of work you could probably get the number of profiles down to 3 or 4 maybe 5. There are also some changes to the profiles as well that you might want to look at. Apply KIS (keep it simple) Principle when ever possible. Other possibilities available. Maybe extrude neck to end face and loft the body with a blend into neck.
Hope this helps.
https://cad.onshape.com/documents/91468b8b28df16766ab209c3/w/e2a7027d8421dec2dadea475/e/dc9592978c1572b0740916ff
