Dimension tool not working
sam_chesnuttsam_chesnutt Member Posts: 5
M2 MacBook.
OS 13.3
Chrome
The dimension tool does not work. I have tried restarting Chrome but no luck.  I have followed the video tutorial to the "T" clicking only once and dragging but nothing.  Suggestions?
  • S1monS1mon Member Posts: 3,408 PRO
    It's very hard to figure out what's happening without a video or something, but assuming you're talking about within sketcher, the dimension tool works just fine.
    When you say it's not working, what exactly are you doing?
  • sam_chesnuttsam_chesnutt Member Posts: 5
    After drawing a rectangle, I wanted to size it.  I click on one of the parallel lines and drag expecting the dimensional lines and size box.  I get nothing.
    Video: https://www.dropbox.com/scl/fi/hfc4yd7az18he2qy6fco2/Screen-Recording-2023-08-23-at-10.59.08-PM.mov?rlkey=5b20pdv0l2fe8kwzvah9l5hvb&dl=0
    After drawing a rectangle, I wanted to size it.  I click on one of the parallel lines and drag expecting the dimensional lines and size box.  I get nothing. I have tried Safari and Chrome.
  • _anton_anton Member, Onshape Employees Posts: 468
    edited August 2023
    Select the dimension tool. Then just click on the sketch line once, don't drag. Then move your mouse to position the dimension, then click again.
