have a problem in sweep feature doesn't make the correct
beshoy_nabilbeshoy_nabil Member Posts: 2
  • S1monS1mon Member Posts: 4,052 PRO
    The sweep is self-intersecting. You'll need to break up the problem somehow.
    You could sweep each side as separate parts, revolve the parts of the corners which are missing, and then boolean those all together.
    Or you could sweep the part of the profile which is outside of the sweep path, and then construct the inside separately.
    If you remove the small radii from the path and a sweep like this will work, even though it's self-intersecting. You could add the corner fillets after.
