How do I query an object after a boolean union?
I'm creating a feature that allows me to extend multiple walls up to a target height.
I see the advice to use startTracking and I've tried that, but no luck.
What am I missing?
Below is my code snippet and a link to the FeatureScript
- Select the top face of a wall element.
- opExtrude a calculated distance to create a new wall element.
- opBoolean union to join the two parts
- I need to select the part created with the opBoolean to modify its attributes.
What am I missing?
opExtrude(context, id + "extrude1", {
"entities" : entity,
"direction" : myMate.zAxis,
"endBound" : BoundingType.BLIND,
"endDepth" : extendedH,
const partsToBoolean = qUnion(qOriginalPart, qCreatedBy(id + "extrude1", EntityType.BODY));
var mergedPart = startTracking(context, partsToBoolean);
opBoolean(context, id + "boolean1", {
"tools" : partsToBoolean,
"operationType" : BooleanOperationType.UNION
debug(context, mergedPart, DebugColor.GREEN);
MichaelPascoe Member Posts: 2,583 PRO
Have you tried makeRobustQuery() ?
Something like this perhaps:var partsToBoolean = qUnion(qOriginalPart, qCreatedBy(id + "extrude1", EntityType.BODY)); partsToBoolean = makeRobustQuery(context, partsToBoolean); opBoolean(context, id + "boolean1", { "tools" : partsToBoolean, "operationType" : BooleanOperationType.UNION }); debug(context, partsToBoolean, DebugColor.GREEN);
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0 -
Here are the steps I take:- Select the code in FS and copy.
- Within the forum post, select the paragraph format "code".
- Paste the code into the code formatted area.
It's very picky. If you mess the steps up, sometimes it corrupts the format and you have to delete everything and try again.Learn more about the Gospel of Christ ( Here )
