I'm trying to add a cut list to the part studio:
 but I get an error that states that it failed to find start and end faces of the frame. I've tried with individual parts and selecting all frames.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,623 PRO
    My guess is that you add cuts or made some changes "manually" that removed the end faces outside of the frame tools.
    You should be able to use "move face" and "replace face" but if you do a cut extrude for example if will eliminate the face created by the tool. Using a "frame trim" might help...
