How do I query an object after a boolean union?
monroe_weber_shirk
Member Posts: 103 EDU
I'm creating a feature that allows me to extend multiple walls up to a target height.
I see the advice to use startTracking and I've tried that, but no luck.
What am I missing?
Below is my code snippet and a link to the FeatureScript
- Select the top face of a wall element.
- opExtrude a calculated distance to create a new wall element.
- opBoolean union to join the two parts
- I need to select the part created with the opBoolean to modify its attributes.
What am I missing?
opExtrude(context, id + "extrude1", {
"entities" : entity,
"direction" : myMate.zAxis,
"endBound" : BoundingType.BLIND,
"endDepth" : extendedH,
const partsToBoolean = qUnion(qOriginalPart, qCreatedBy(id + "extrude1", EntityType.BODY));
var mergedPart = startTracking(context, partsToBoolean);
opBoolean(context, id + "boolean1", {
"tools" : partsToBoolean,
"operationType" : BooleanOperationType.UNION
debug(context, mergedPart, DebugColor.GREEN);
MichaelPascoe
Member Posts: 2,803 PRO
Have you tried makeRobustQuery() ?
Something like this perhaps:var partsToBoolean = qUnion(qOriginalPart, qCreatedBy(id + "extrude1", EntityType.BODY)); partsToBoolean = makeRobustQuery(context, partsToBoolean); opBoolean(context, id + "boolean1", { "tools" : partsToBoolean, "operationType" : BooleanOperationType.UNION }); debug(context, partsToBoolean, DebugColor.GREEN);
RENDERCAD
________________________________________________________________________0 -
MichaelPascoe
Here are the steps I take:- Select the code in FS and copy.
- Within the forum post, select the paragraph format "code".
- Paste the code into the code formatted area.
RENDERCAD
var partsToBoolean = qUnion(qOriginalPart, qCreatedBy(id + "extrude1", EntityType.BODY)); partsToBoolean = makeRobustQuery(context, partsToBoolean); opBoolean(context, id + "boolean1", { "tools" : partsToBoolean, "operationType" : BooleanOperationType.UNION }); debug(context, partsToBoolean, DebugColor.GREEN);RENDERCAD
It's very picky. If you mess the steps up, sometimes it corrupts the format and you have to delete everything and try again.RENDERCAD
