Importing and moving parts into the same part studio tab
jonatan
Member Posts: 9 ✭
Hello everyone!
New user here, moving from Fusion360. I have been watching tons of tutorials on Youtube to learn the basics and I'm having a problem related to the parts.
Here's my example file → https://cad.onshape.com/documents/e68ecac8a384518d210b3b3a/w/5eee79d9729b7203be267191/e/b04f9d3cd13e6e19d5ec71e3?renderMode=0&uiState=64eb81271e7e3835c855555b
As you can see I have imported two CAD models I downloaded. Each model is imported into a different part studio tab.
FOR THE LOVE OF SNOOPY I'm not able to find a way to move those parts into the same tab which I called "move parts here". How do I do that?
I need to do this because I want to work on a box for a sensor I will print later and I need these CAD models to be in the same parts studio tab to easily design the box. I'm seeing there's an Assembly tab where I can insert parts, but I'm not able to design the box here so this is not useful for me
Thanks for absolutely any info on how to do this!
S1mon
Member Posts: 3,768 PRO
You can derive the parts from one part studio into the other.Simon Gatrall | Product Development Specialist | Open For Work
1
https://cad.onshape.com/documents/65880199ca89dcea23415b48/w/ec02b5bc27605aedb1b757ed/e/20110341acceff41d977629d
YouTube examples are OK but OS provides very good instruction.
https://learn.onshape.com/learn/course/managed-in-context-design/completion-certificate/completion-survey?page=3
@glen_dewsbury sorry, I looked at your file but I couldn't understand what you mean, I'm still not able to edit in the Assembly tab the box you designed in the part tab.
Personally I think was well worth my time to go through OS tutorial. When you are ready just insert the new part into the assembly. Note that I renamed the context to make it easier to keep track off.
https://cad.onshape.com/documents/65880199ca89dcea23415b48/w/ec02b5bc27605aedb1b757ed/e/2457a04abd5e11a04c6eaf68
