Is there a way to have 2 profiles in a Frame Sketch
glen_dewsburyglen_dewsbury Member Posts: 1,223 PRO
I have a set of extrusions that are absolutely always used in pairs with brackets to keep hem assembled. They are in fact assembled before mitering ends.
When tried using a sketch with 2 profiles included the result is failure in the frame feature. No error messages, just nothing appears.
Is there a way to accomplish this as a single as a single frame?
At this point I have to make 2 frame features consisting of the same profile with an offset reference point for centering.
If this can't be accomplished I'll put in an IR.
