Trouble Selecting Details in Drawings
S_HansenS_Hansen Member Posts: 5 PRO
Over the past couple weeks I have noticed a difficulty in selecting things in drawings, such as dimensions, drawing views etc. Quite often I have to click outside of Onshape, then return to Onshape click the items. Other times I have to right-click and edit text instead of simply double-clicking the text, or select a different annotation then select the one I want to edit. This wasn't a problem before a couple weeks ago. Has anybody else experienced this recently?
  • PattabiPattabi Member Posts: 51 ✭✭
    @S_HansenRecently I am not working much with drawing. Is it in any specific drawing document or in all?
  • S_HansenS_Hansen Member Posts: 5 PRO
    It's happening in all of the drawings I've been working with.
    If it is not confidential you can share it with me. or try escalating it directly to the Onshape support from any document that you are facing the issue.
