Offset surface to a sketch to create a new surface - Custom Feature
ben_partouch
Member, csevp Posts: 159 PRO
Hello,
My custom feature generates a sketch. I'd like to add the function of offsetting that sketch so a new surface is created. Similar to what I would manually do with the Offset surface native tool.
opOffsetFace doesn't seem to work, and offsetSurface commend seems to not exist anymore?..
What would you recommend?
Thank you
Thank you
opExtractSurface(context, id, { "faces" : someFace, "offset" : 25 * inch });
I think you nailed it.
