DISAPPEARED DRAWINGS ON DOCUMENTS
in General
Today I open a document and find that the drawings created in the document are blank pages; not even the sheet with the headings is visible: just a blank page. I have tried opening other documents, including those created by other users, and the result is the same. What has changed? I also tried testing the system with Onshape's 'System Check' utility, with positive results. Can anyone help me?
See one documents of mine on following URL
Could it be....dependent on? If it is not understood why, it may not be temporary....
what browser are you using
