DISAPPEARED DRAWINGS ON DOCUMENTS
Valerio_RossoniValerio_Rossoni Member Posts: 19
Today I open a document and find that the drawings created in the document are blank pages; not even the sheet with the headings is visible: just a blank page. I have tried opening other documents, including those created by other users, and the result is the same. What has changed? I also tried testing the system with Onshape's 'System Check' utility, with positive results. Can anyone help me?
See one documents of mine on following URL
  • S1monS1mon Member Posts: 3,373 PRO
    Looks just fine. Perhaps there was some weird temporary issue?
  • doug_scottdoug_scott Member Posts: 11 ✭✭
    I'm  experiencing the same problem right now.
    my latest drawings have have vanished.
  • Valerio_RossoniValerio_Rossoni Member Posts: 19
    Could it depend on the latest improvement released? I know one was implemented on september 1st
    S1mon ha detto:
    Could it be....dependent on? If it is not understood why, it may not be temporary....
    doug_scott ha detto:
    what browser are you using
    I have opened a ticket, the support has worked about, and now the problem is solved.
