Divide line
steven_mcardle
Member Posts: 13 ✭
Hi.
I have a line, say 13 meters long, and I want to draw a perpendicular construction line every meter.
The catch is, if I now change the original line length to 15 mts I want it to auto add the missing construction lines. Likewise if I make the original line shorter I want it to remove the extras.
Basically, auto calculate the number of construction line at X distance apart for a line length of Y..
Does anybody have any ideas how to do this ?
Thanks. Steve
Thanks. Steve
I am going to use the construction like to attach new planes perpendicular to the centre line.
The construction lines represent stations in a boat hull and the attached planes will be used to represent each of frames at that stations
