How do I use the loft tool for this?
vaclav_novak
Member Posts: 5 EDU
I got my Airfoil shape (I used a featurescript) and I got my wing shape now I need to use the loft tool to completely make the wing. But whenever I and try to make the loft follow a path, it just completly dies. please help
The splines used as loft guides are 3Dfitspline. The curves in sketch1 do not pass through profiles and will give an error for loft.
The part studio copy is a surface. Use a solid or surface as you decide is appropriate.
Hope this gets you started.
https://cad.onshape.com/documents/93e5bca38b14187ba45986e9/w/71f796830279a0dec5ecaeb4/e/480def3e96511d3f7d5e3464
