Problems with tangency constraints on a fill feature
ronny_brekke
Member Posts: 5 ✭
I'm pretty new to onshape, and bumps into stuff all the time. But this, I don't know what to do. I'm trying to make a car hood with an indention in it. I've made a outline surface of the hood, and I've cut out a hole where I want the indention. I've cut up the hood to make tangency patches for a fill. I'm getting a kind of result, but I get some error messages, and all though I have a solid surface I can't thicken it, as it's something wrong.
If someone could look at my model and tell me what I'm doing wrong, and how I really should do it, I would very much appreciate it.
Onshape document
Onshape document
ronny_brekke
Member Posts: 5 ✭
Thanks for your replies. The solution got to complex for me, so I did it in a simpler, less accurate way. I made a sweep along the bottom indent curve to create a surface, and merged the two, and finally made a fillet around the edge.
The solution, if anyone's interested.1
