Options to italicized text / slanted letters
Hi,
Is there any option to create slanted text by specific degree and direction? Like italic font but with options on how much 'italic' it can be and direction, every italic font is slanted to the right.
Like on example above, I want to make this text to be slanted as selected construction line. To create this I used Surface text but it doesn't have options I'm describing.
Thanks
Thanks
I looked into some custom scale or skew features, but didn't find anything that nicely skewed. Aside from creating a drawing, custom feature, or importing an already skewed text, you could use Move face rotate:
It only worked well on the square text: T, E, F, not the "X", so you will need to create a separate move face for that one in order to rotate about it's center.
https://cad.onshape.com/documents/32c9760936651f531fd17403/w/b360141d2916c2ae17a75de5/e/a63fca88760050...
