Shaded View is Pixelated in Large Drawing
I made a very large scale drawing (it's going to be printed as a vinyl banner and used as a layout for a robotics course). The sheet is 132x86 inches and the stripes shown in this image are about 3 inches wide. To get the stripes to be solid black (and other areas to be in color) I turned on "show shaded view." It seems that the shading is some kind of "fill" applied to the drawing and it is being generated at a lower resolution than the lines themselves. Are there any settings to adjust this? I have already changed the sheet from "best performance" to "best quality."
Here is a link to the document: https://cad.onshape.com/documents/93347d0857014e34ce5e8ee6/w/01d3f9362f2cc9ecb280f67e/e/68d657a5378b65c5fec37d3d
eric_pesty Member Posts: 2,378 PRO
I don't think this is the right tool for this... Not only does it create a fairly low resolution image but the shaded views also have some lighting effects applied so the colors aren't going to be easy to control and not "correct" (i.e. black won't really be black).
I can't seem to see that where that is coming from in your linked document but a better option would be to create a section through the model on the drawing and set the hatch to "solid" (an not use shaded views at all).
1
