Best ways to create a 1:1 relationship between a set of queries and some other settings?
EvanReese
Member, Mentor Posts: 2,832 PRO
I'm working on a feature that generates a list of parts, which should have some values associated with them by the feature. Later (in the same feature), when I query one of those parts, I want to be able to get a list of the settings for it. I thought I might be able to use the query itself as the key to a map, which would have all of the settings in it, but that didn't seem to work. I think I could use attributes, but I don't need to access this info in a downstream feature, so it doesn't feel quite right. Maybe that doesn't matter though. Any ideas on how to approach this?
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,254
Attributes sounds right -- it doesn't matter if it's the same feature. If you like, you can clear them at the end of your feature.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
