How to split a closed spline into two equal areas
Newbie user here. I need to split a closed spline into 2 equal areas but can't figure it out. Using the spline in this sketch, how can I accomplish it? TIA
MichaelPascoe Member Posts: 2,279 PRO
@mike_bodie, @S1mon is right.
Here are two custom feature that can handle this. Visit their documents to add them to your toolbar. The small + button at the top of the document.
Find solution by @Konstantin_Sh and Volume optimizer by myself.
Find solution is more universal and will let you solve for anything you can measure, use Measure values also by Konstantin to get those values. Volume optimizer on the other hand, is specifically made for volumes and areas.
Here is an example of how to use Volume optimizer:
https://cad.onshape.com/documents/241967ce0e2d785e31a36150/w/440cbc094cf1d707ac543cb6/e/2c595717a1fefb703...
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴3
Independent Onshape Consultant
I think Konstantin's is posted deep within the "custom feature show and tell" post and mine hasn't been posted yet.
