Merging 2 documents in to a single, in same tab
Hi all. I searched the forums but was unable to find exactly what I was looking for so I thought I would ask.
I created a drawing, but thought I could improve upon it with the addition of a small part. I created the small part in a totally separate drawing since I knew I would need to print it several times to adjust its fit. Now that I have it finalized, I would like to add it to my other drawing and integrate it, but for some reason unable to do so. I can get it as a seperate tab, but I need to 'attach' the two parts together. Any tips appreciated!
bob
If in real life it will all be one piece printed together, then derived, as eric above mentioned, would work.
ps, "drawing" means a piece of paper with multiple views of a part with dimensions, your name to take credit, and the revision history, etc. "3D model" or "solid model", is the term you are looking for.
Either way, I still think a derive feature is what you need but it would be easier to follow what you are asking if you used the correct terminology...
Maybe start with some of the courses in the learning center like this one: https://learn.onshape.com/catalog?labels=["Self-Paced Courses"]&values=["Onshape Fundamentals"]?
