Slick trick for force closing a sketch profile in FS?
Stormi_Backus
Member Posts: 49 ✭
Howdy,
My company recently switched to OS from Alibre so I am re-vamping all of our configurators with FS. This went super well for roller chain sprockets/bushings but I am struggling with welded steel and pintle chain sprockets because the mathematics in the ASME are JUST imprecise enough to prevent a closed sketch profile. We're talking 0.000000 - OnShape can't even measure the distance between the point and circle highlighted below.
I found a way around this by using configurations instead of featurescript as you can see here, but my coworkers vastly prefer having the FS in their toolbar over having to insert a configuration.
So, I am wondering, does any one have a slick trick for forcing a closed profile in featurescript? Maybe there's something obvious I am over looking? Any solution I've thought of wouldn't hold true from part to part. Thanks!
It is likely that fill will still close it.
if the edges that are supposed to be touching, do not meet at a vertex, then it gets more complicated.
If they do meet at a vertex, you can modify the arcs, lines by just creating a new sketch with the existing geometry's data. if it is a spline, its safe in this case to get the bspline curve and just adjust one of the end points to meet correctly.
https://cad.onshape.com/documents/a4d1c9f3b7a0d44474d08e3a/w/bc8c3641dcb96ce97747b8c3/e/83c5157ece1ed11095b76673?renderMode=0&uiState=65086c2fc0945d677f732a03
I cant even find what you are referring to in the model.
