Link part/assembly properties to drawing properties
leon_tulling
Member Posts: 12 PRO
in Drawings
I want to link part or assembly properties to drawing properties automatically.
For example, if the part number of a part or assembly is '100-0001', I want the part number of the drawing also to be '100-0001'. Now, we have to do this manually, but I would like to have it done automatic.
I would like to do the same for name and description.
I allready have the part number uniqueness set, that the drawing can reuse the part number from an assembly or part.
Is there an option, featurescript or other solution for this?
I've tried to search for this on the forums/internet, but couldn't find anything usefull. Maybe I have used the wrong search criteria?
Creative Technician Mechatronics | Freelance Engineer
www.leontulling.nl
www.leontulling.nl
This value is linked to the part code in the parts properties.
Just a FYI, the option you have selected will only allow you to create a drawing with the same part number as the part. I may be wrong but parts and assemblies would still need to have different part numbers
So to take the image below as example, the red-bordered part number box of the drawing should, autmatically, be the same number as the part (000015)
www.leontulling.nl
This doesn't automatically set the drawing part number to the referenced part number though...
www.leontulling.nl
