How do I combine multiple parts into one? Murph
My sketch is multiple parts.  How do I combine into one for 3D printing?
Can I modify it afterward?
  • MichaelPascoeMichaelPascoe Member Posts: 2,821 PRO
    edited September 2023
    For 3d printing you don't have to merge them as long as you are exporting the entire part studio in the STL format. However, if you still want to merge them, use the Boolean feature. There is a search bar at the top right of your studio, this is helpful for finding features.
    Also, have a look at the Learning Pathways in the Learning Center. These will boost your Onshape efficiency quite a bit.
    RENDERCAD
