Changing reference in a drawing
patrick_sheapatrick_shea Member Posts: 63 EDU
When you have created a drawing from a model - example below - roller 1.  Can I copy that drawing, and then use a new (similar) reference - say "roller 2", to create a new drawing.  I used to be able to do something like that with Solidworks.
Pat
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 153
    Hey @patrick_shea,
    If you open the sheet fly-out menu on the left you can replace the reference for one or multiple views.
    Hope this helps. Cheers
  • patrick_sheapatrick_shea Member Posts: 63 EDU
    Thank you !!  I knew there should be a simple solution, if I asked the right question.
    It is nice you similar items, so you don't have to re-create the whole drawing evrey time.
    Thanks again
    Pat
