how to recentre my part
Hi, I have drawn my part, unfortunately, upside down, so I used the transform tool to spin it 180deg but now it is not centred over my origin.
Is there a way to recentre my part.
Thank you
John
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @john_charles783,
    It's always handy to share a link to your public document so people can have a look directly in there. If possible I would probably make some changes to the sketch rather than using the transform tool unless that is too complex.
    I you use the transform tool to rotate a part along an axis, you can use mate connector placed on the origin to o this rotation. This way your part will remain centred over the origin.
    You can find more info about mate connectors here:
    https://cad.onshape.com/help/Content/mateconnector_a.htm
    https://learn.onshape.com/learn/article/all-the-ways-to-use-mate-connectors
    Any questions, let me know. Cheers
  • john_charles783john_charles783 Member Posts: 4
    Thanks David, I will give your idea a go and follow those links. What I found yesterday was that when it went into assemblies tab the transform tool was much easier to use than it is in the parts tab and I was able to easily spin and place the part and the origin wasnt an issue. I think I should start with simpler parts to learn using the transform tool because my part had many pieces but once in the assembly tab it was just one.
    Thanks again
    John
    No worries @john_charles783,
    if you want to share your (public) document people can also have a closer look to better understand your issue. Cheers
