how to recentre my part
john_charles783
Member Posts: 4 ✭
Hi, I have drawn my part, unfortunately, upside down, so I used the transform tool to spin it 180deg but now it is not centred over my origin.
Is there a way to recentre my part.
Thank you
John
Thank you
John
David_YL_Nguyen
Member, Onshape Employees Posts: 182
Hey @john_charles783,
It's always handy to share a link to your public document so people can have a look directly in there. If possible I would probably make some changes to the sketch rather than using the transform tool unless that is too complex.
I you use the transform tool to rotate a part along an axis, you can use mate connector placed on the origin to o this rotation. This way your part will remain centred over the origin.
You can find more info about mate connectors here:
https://cad.onshape.com/help/Content/mateconnector_a.htm
https://learn.onshape.com/learn/article/all-the-ways-to-use-mate-connectors
Any questions, let me know. Cheers0
Thanks again
John
if you want to share your (public) document people can also have a closer look to better understand your issue. Cheers
