condition in the if statement is failing
I am using the following script to create a three-stepped cylinder, I want the diameter for step 1 and 2 to depend on the selected value of dia3 from the lookup table/sizeTable. The condition in the if statement is failing though! can someone provide some guidance?
FeatureScript 2144;
import(path : "onshape/std/common.fs", version : "2144.0");
export const sizeTable = {
        "name" : "dia3",
        "displayName" : "Dia3",
        "default" : "25",
        "entries" : {
            "25" : {
                "name" : "StockHeight",
                "displayName" : "StockHeight",
                "default" : "140",
                "entries" : {
                    "60" : 60 * millimeter,
                    "100" : 100 * millimeter,
                    "127" : 127 * millimeter,
                    "140" : 140 * millimeter
            "20" : {
                "default" : "125",
                "entries" : {
                    "84" : 84 * millimeter,
                    "104" : 104 * millimeter,
                    "125" : 125 * millimeter
annotation { "Feature Type Name" : "Tool4" }
export const tool4 = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Tool height", "Lookup Table" : sizeTable }
        definition.sizeTable is LookupTablePath;
        if (definition.sizeTable.dia3=="25")
            annotation { "Name" : "Dia1" }
            isLength(definition.dia1, { (millimeter) : [1, 14, 14] } as LengthBoundSpec);
            annotation { "Name" : "Dia2" }
            isLength(definition.dia2, { (millimeter) : [14, 16, 19] } as LengthBoundSpec);
        annotation { "Name" : "height1" }
        isLength(definition.height1, { (millimeter) : [1, 20, 100] } as LengthBoundSpec);
        annotation { "Name" : "height2" }
        isLength(definition.height2, { (millimeter) : [1, 20, 100] } as LengthBoundSpec);
  • Jacob_CorderJacob_Corder Member Posts: 141 PRO
    FeatureScript 2144;
            "name" : "dia3",
            "default" : "25",
            "entries" : {
                "25" : {
                    "default" : "140",
                    "entries" : {
                "20" : {
                    "default" : "125",
                    "entries" : {
    annotation { "Feature Type Name" : "Tool4","Editing Logic Function":"tool4EditLogic" }
        precondition
            annotation { "Name" : "showDia1","UIHint":UIHint.ALWAYS_HIDDEN }
            definition.showDia1 is boolean;
             annotation { "Name" : "showDia2","UIHint":UIHint.ALWAYS_HIDDEN }
            definition.showDia2 is boolean;
            if (definition.showDia1 )
            if(definition.showDia2)
        export function tool4EditLogic(context is Context, id is Id, oldDefinition is map, definition is map,
        isCreating is boolean, specifiedParameters is map, hiddenBodies is Query) returns map
         definition.showDia1=false;
            definition.showDia2 =false;
        println(definition.sizeTable.dia3);
        if(definition.sizeTable.dia3 =="25")
            definition.showDia1=true;
            definition.showDia2 =true;
        return definition;
    You will need editing logic for this to work.
  • Mohamed_AlieddinMohamed_Alieddin Member Posts: 5 PRO
    FeatureScript 2144;
            "name" : "dia3",
            "default" : "25",
            "entries" : {
                "25" : {
                    "default" : "140",
                    "entries" : {
                "20" : {
                    "default" : "125",
                    "entries" : {
        precondition
        return definition;
    Jacob, thanks a lot for your comment!. This works but I am trying to create a logic that would make the max value in lengthbound of dia2 < the selected dia3, and the max value in lengthbound of dia1<dia2. Do you think this is possible?
    @User1_Livetools
    You can only over ride a users input in edit logic so if someone types in a value too big or small, you just modify it to the min value if too small or the max value if too big. Just set it in the edit logic function that I provided above
