Extrusion of holes
I try to make tree linear extrusion holes. Hole 2 and 3 work ok. Hole 4 which should be equal to 3 is "rejectet" (Volume body remove 4mm)
https://cad.onshape.com/documents/a72637427309583c2d976630/w/8a6fd454718c031daa3ab74c/e/662d1dc38f10a22532889cb9
You'd need to either move the hole, change its size, or change that counterbore depth.
https://cad.onshape.com/documents/ee8a1a5676a5cf43bf2d9483/w/431017a1295aaf20823f4425/e/db06211b4fd851a24f40a3cb
