Unsure why I cannot extrude whole sketch
Working on a project for school and cannot figure out why the last area of my part here isn't shaded.  Can anyone see what I'm doing wrong?
Thanks for your time!
  • S1monS1mon Member Posts: 3,949 PRO
    It's hard to be sure without seeing the document, but it looks like the bottom line is not connected at the bottom two corners. Somehow it was moved or sketched without automatically creating coincident constraints at the corners.
  • PattabiPattabi Member Posts: 54 ✭✭
    @christopher_freidIt's because your sketch is not completely closed. Based on your image, I believe these part is not closed. You can also differentiate by the shading if the sketch contour is closed.
