Why can't I fillet this piece?
lance_leasure
Member Posts: 10 ✭
Hello!
I'm trying to create a fillet along the inside of this piece ("Base" Part Studio, along the joint of the walls and floor of the piece). Where I'm getting hung up is that I need the fillet to be 1/2" along the longer edges (parallel to the front plane) and 3/4" along the shorter edges (parallel to the right plane). Can you help me figure this out, please? Here is a link to the public document.
https://cad.onshape.com/documents/14ad76501f82bf59fc783ede/w/8fbf3a78249704753412f422/e/0be58f44af72b9a43f708045
Thank you!
Thank you!
MichaelPascoe
Member Posts: 2,703 PRO
Glen and David are right. There was also a line overlapping your spline causing that particular portion of the spline to mess up. After deleting that overlapping line and making the splines tangent with the tangent constraint, it should work:
https://cad.onshape.com/documents/43820f1ddba43e49cef4361d/w/b495bb0a3678cbb7d047d5aa/e/207aa300d2a...
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
If you would be able to make the underlying curves/splines tangent to each other in the transitions, I think this would hep greatly with creating of the fillet. Cheers
