Gears thooth coliding on gear relation
akko_hoshinoakko_hoshino Member Posts: 4
Im new, and i'm trying to make a simple very simple gear relation but the gears collide, no matter what I do I cant work around them colliding, it always resets itself when I try to do the gear relation. Please help. I would appreciate it
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 851 PRO
    Expand one of the revolute mates involved with your gear relation.  Edit one of the mate connectors.  Check off the "Move" checkbox and add a rotation.
  • akko_hoshinoakko_hoshino Member Posts: 4
    Most of the time it does not work
    before
    after
    There is not change
    @akko_hoshino, the trick is to rotate one of the gears by 1/2 tooth (360/n/2 degrees).  Expand the revolute mate for the gear that you would like to rotate.  Typically that will contain two mate connectors.  Edit one of these mate connectors to rotate about the z axis.
