Run Time
wayne_sauderwayne_sauder Member, csevp Posts: 646 PRO
Are there discussions on adding approximate run times? Sometimes it is nice to see the calculated run time and tweek operations to see if there are ways to shorten the cycles. If each operation had an estimated run time I don't know why the program couldn't add them up for an estimated total. I realize this would only be an estimate because of tool changes etc...
