loft with multiple paths
gogos_ppdogogos_ppdo Member Posts: 2
https://cad.onshape.com/documents/12277d0ab670f28bd79771df/w/933a9dda0454cab9dc445d1e/e/f01a7a7b1a48a7c07c6293fe?renderMode=0&uiState=653905854d5b3463e0935642
i am trying to reate a loft between who profiles using two paths but i cant find how. is there any way to loft using multiple paths?
  • Jon_HJon_H Member Posts: 38 PRO
    You can only use one path in Loft but you can use multiple guides in the "Guides and Continuity" section of the Loft tool.
