slider mate help
don_howedon_howe Member Posts: 136 ✭✭✭
I read the help file on the slider mate but I am not sure who to apply it to my design. I have a Revolute mate which rotates my door and what I would like to do is have the door slide back. In my design I have a groove along the edges of the door and a ledger strip that would support the door as it slides back. My document name is Barrister Bookcase 2.0
  • S1monS1mon Member Posts: 3,499 PRO
    edited November 2023
    You should be able to use a pin-slot mate.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 711 EDU
    Maybe not necessary, but I added a 3rd part.  The intermediate part has a pin-slot mate with the main bookshelf and a revolute with the door.
    At first I wrote a very similar answer to @Matt_Shields. You can make a dummy part or even use an assembled sketch as an intermediate. I haven't actually tested it out, but looking at the help documentation it seems like a pin-slot could work, but I'm not sure if the optional limits will work the way you would want.
  • don_howedon_howe Member Posts: 136 ✭✭✭
    @M@Matt_Shields, I think I need to see how you actually did the mates. I have a revolute mate now for the door but when I try the pin-slote mate I get  over defined. So there is something I am missing or not seeing.
  • eric_pestyeric_pesty Member Posts: 2,311 PRO
    @don_howe
    Just a pin slot should work for this (i.e. it would also replace your revolute so I wouldn't worry about them conflicting). I think this is a case where you would have to order the mate selection with the "slot" first and "pin" second.
    See this video for an "in depth" discussion of what I mean:
    https://www.youtube.com/watch?v=9dAkfGNdgGU
    Thanks everyone for you help. I have had a modicum of sucess but I still need help. In the screen captures I've manged to swing the doors open and slide the door back, however as you can see in the bottom image, I can push the door back in an unexpected way. Well, unexpected for me. So, I must have something not set right. I am unsure what "Faces to connect" are doing for me. I have tried negitive intergers in the X and Z limits but that gives error results. What am I missing or not seeing?
    @don_howe
    Hard to see exactly what is going on but try reversing the selection order in the mate dialogue.
    Faces to connect won't do anything for you (i.e. it's just for stress simulation, not "motion" simulation)...
    Re-ordering the mate connetors did not work. It simply pushed the "X" distance on the opposite side and causes the door to swing in from the bottom rather than the top.
    @don_howe
    I'm guessing you need to adjust the mate connector orientation on the door part to be in the sliding direction, and the door mate connector should be first:
    https://cad.onshape.com/documents/68a2bab3a8ebca0071f08603/w/ce288b38b6ec8f3c038a1bbd/e/a2ddeb34f6957755be32926b?renderMode=0&uiState=65455790a607f210024b3d4e
    Eric's solution is much more elegant, but I also managed the movement by creating a dummy part (the transparent one) to constrain the path of the end of the door.  I have two tangent mates, each between one of the gray cylinders and the dummy part.
    @Matt_Shields
    Your solution stops the part from sliding until it has rotated so it's a more accurate representation of the actual motion.
    I tried adding a tangent mate as well and sort of works but gets "stuck" when dragging (unless you make sure to "pull" it out against the slider limit) so it's not great:
    @ eric_pesty
    I tried the tangent mate and as you say it gets stuck.
