Variable table "Filter feature list" behavior changed?
eric_pesty
Member, pcbaevp Posts: 2,549 PRO
I might be crazy but i thought when you used the "Filter feature list" from the variable table it used to show just the features that used that variable.
I tried it today and it just shows the "variable" feature only, which seems pretty useless...
Anyone else remember the "old" behavior or did I dream that up?
I am aware of the dependency list but I swear the "filter feature list" from the table used to isolate the things that cross-highlight when you mouse over in the tree (which would make a lot more sense) but I wanted to check here to see if I was just making it up!
If this doesn't get "picked up" by Onshape support from this thread I'll submit a ticket...
The only thing it seems to be useful for is finding the variable if it's well down through a very busy feature list. Useful if you're want to move it in the feature tree since setting var can be done in the list.
