Using the Circular Pattern command how do I place 12 holes 30deg apart around an outer surface
I've produced probably over 1000 designs using Onshape over the past four years. However, I have not needed to use the Circular Pattern command on the outside surface of a Round bar before now. I have done something wrong with using this command, can someone please point me in the right direction?
The part that I am trying to create is the hub of a spoked wheel, I need to place 12 spoke holes 30deg apart into the hub.
Please refer to the image below to see the method used so far.
Your help will be most appreciated.
glen_dewsbury Member Posts: 1,139 PRO
Try switching to feature pattern. Looks like you're trying to make a circular 'part' pattern on top of it's self kinda.
romeograham Member, csevp Posts: 715 PRO
The feature that you are patterning was created by the Hole feature. In the last Update (only 3 weeks ago!) the Hole feature was updated to rename the feature to match hole. In your case, you made a Hole that has [diameter] 0.5 inches, and [depth] 0.5 inches.
EDIT: I just realized that @glen_dewsbury used the Hole feature - not your original post.
Thank you both so much for your prompt replies, it is most appreciated.
