Can I make a "transition" or "fill" in this model between two extrusions?
Hi there. I have made a model and would like to make a "fill" between two extrusions. I have no idea how to approach this, so any suggestions would be welcome.
I want to make a smooth transition between the area in yellow, and the sides of the cylinder. I have tried to indicate with red lines on the drawing.
How would I approach this?
Its very simple extrusions from the top plane, and a fillet.
  • MichaelPascoeMichaelPascoe Member Posts: 2,812 PRO
    edited November 2023 Answer ✓
    @madsdyd, try Fillet or Face blend. If those don't work you could use Loft or Fill. If you're still having trouble, share a link to your document and we'll help you out.
    RENDERCAD
    RENDERCAD
  • Thank you very much! Face blend seems to do "almost" what I want. Might just need to learn the parameters ;-)
