Help creating a recessed ceiling mount
Hi! I'm working on a presence detection sensor that I want to mount on the ceiling. I want this sensor to also be able to rotate a bit so I can adjust the detection zone. On this onshape file you will find one of my ideas so far, using magnets (keep in mind this is just a quick one to show what I'm thinking, sizes and alignment of parts might not be correct). I'm wondering if there's a better way to do this so I want to ask all of you!
Some of my needs are:
1. Should be able to 3D print
2. Should be able to snap in and out (the sensor part) so I can work on the sensor, and change components (that's why I'm using a magnet)
3. Should have some friction so it doesn't move easily
Quick video showing how it would look and move on the ceiling
It's just my own design, I will have to design both the box for the sensor and the holder that attaches to the ceiling. Currently, I'm only doing tests with the sensor itself in a rounded box
Uhhh I like this idea, seems quite simple. I guess instead of adding a steel strip I could just add another magnet inside the rounded part of the sensor (add a half circle on top of it as the steel strip) and add some texture to the plastic to generate some friction?
i think I will try to do something that’s 3D printed + magnets or something else only, so I can easily reproduce it
