Rotating Sketch Features
stuart_everystuart_every Member Posts: 3
edited December 2016 in Community Support
Drew a feature in a Sketch, and then needed to change its position on the Component Circumference.
Couldn't figure out how to Rotate these features, nor how to choose a Centre of Rotation.
Ended up using the Transform (I think) function, which gave me the white arrow Tool. I dragged the 'point' of this tool, to the Rotation Centre, then used the Rotate icon to select that function, then inputed the angle; all ok so far...
Then clicked the left button to OK the change, at which point the feature shot across to a random point in the Sketch
What am I doing wrong here?
  • shade_wilsonshade_wilson Member Posts: 2
    How do you rotate a sketch in 3D? For example, if you were facing the object in the same direction the entire time and then rotating it exactly 90 degrees, it would look completely flat, just like turning around a piece of paper. I cannot figure out how to do this.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,057 image
    Edit the sketch plane in the sketch dialog to point to a plane at 90 degrees
  • robert_stilesrobert_stiles Member Posts: 186 PRO
    @NeilCooke what if you create a sketch, you need it initially where you have created it, but then you also need the same sketch, rotated 90 degrees in its x or y axis later downstream ?
    I can't re-set its plane, because I need it where it is initially
    I can't projects any content because its 90 degrees rotated...
    do I have to create a further sketch @ 45 degrees and double project around the corner? Seems a bit heavy. The transform feature can't pick sketches unless I'm missing something?
    Any other workflows?
    Thanks
    Rob
    @robert_stiles you would have to create a new sketch and paste the entities into it, although they would not be linked. Alternatively, if the sketch is closed, you could create a zero offset surface on the sketch face, then transform the surface then use that for extrude etc.
    @NeilCooke, thankyou so much for the reply.
    The second option will work for me, thanks.
    It would be good if you could apply the transform feature to sketches though !
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,762 PRO
    Another option would be to do a circular pattern on the sketch feature (if all you need is a 90deg "offset").
    One more alternative is to use the "transform pattern" custom feature (if a simple circular pattern doesn't give you enough control) which does allow transforming a sketch (similar to the zero offset surface) to save a step.
    Also, if it is an extrude you're creating, rather than transform the sketch, create the first extrude as a new part, transform/copy, then merge both into the main part.
    Ah @eric_pesty... pattern a feature - of course. I should have known that. (there no face-plant emoji ? now there's a valid Improvement request if ever I came up with one)
    Thanks everyone. Very speedy responses.
