How do I check what material is applied?
sean_trainor1988
Member Posts: 15 ✭✭
When I am working on a part, how do I know if a material has already been applied, or what material has been applied?
martin_kopplow
Member Posts: 1,078 PRO
Hi Sean, I understand, though you don't need to dig very deep for this. Just a click on the BOM Tab on the right and one pulldown menu and you get an overview over all your parts and their materials. It even shows "--None--" if you assigned none to a part. Once the column is added, it is even but one single mouse click and just as top level as looking it up in the tree.What I actually miss in that context is being able to assign materials from within the BOM table, ideally by multi-selecting parts there and then bulk-assigning materials to all of them. This could be quite helpful for larger assemblies.0
I've also just noticed that if I go to apply a material to a part which already has a material applied, it will show me the current material there.
